No spark - Ford Forum - Enthusiast Forums for Ford Owners
LinkBack Thread Tools Search this Thread
Old 01-30-2012, 11:38 AM
Default No spark
1997 mercury sable, (taurus twin)
I had a blown head gasket, engine had 209,000 so I decided to pull the motor and do a slight rebuild and clean of the whole thing. Everything went good and once I got it back together it won't start, does not have spark.
I caught someone moving the crank shaft sensor
http://www.justanswer.com/uploads/ba...taurus_cmp.gif
And of course I rotated the engine to clean the cylinders so the ignition timing is all messed up now.
I need to know hot to re sync the ignition timing so it fires correctly. And not by marking the way it is.. because its all messed up.. i need to know how to do it from scratch.. setting cylinder 1 to top dead center or whatever i have to do to set this back in right...
Any help is great help.. or if you know where i can find this info it would be great...
thanks for your time,
Fred
Old 01-31-2012, 06:13 AM
Have you solved your problem yet?
Old 02-01-2012, 04:20 AM
Since we haven't heard from you, is it safe to assume you found the answer to how to set the cam synchronizer ?
Old 02-02-2012, 06:16 PM
I did figure that out.. I just had to clean the ground better and I got spark.
Now im having a cylinder 2 miss fire.
When I took the lifters out.. all of them where depressed down. I had to use cleaner to break them loose.. i then took them apart and cleaned them all really good and reinstalled them. is there a possibility that the lifter could be bad?
there is a slapping noise right around cylinder 2 its a ticking.. sounds like a bad lifter.
Is it possible that the lifter being bad, is not allowing the push rod to tilt the rocker, in turn not opening a valve? causing the miss fire?
Old 02-02-2012, 07:40 PM
Yes ,I would think that is a good possibility. Do you have the tools to do a compression check?
Were you able to load the lifters in oil before installing them?
Did you happen to notice if any of the rollers were a little rough?
Thread Thread Starter Forum Replies Last Post
no fuel or spark at spark plug Billy62 Ford F-150 4 03-31-2014 06:08 PM
No spark or intermittent spark, new coil installed JCtrayer Fairlane/Falcon/Galaxie/Gran Torino 1 11-22-2011 11:07 AM
62 Falcon, weak spark/intermittent spark, new coil installed JCtrayer General Tech 13 10-28-2011 06:32 PM
Changed spark plugs now No spark No start Rogerseric Ford Econoline E Series 3 08-12-2011 01:34 PM
little spark, no spark sometimes 289 67comet General Tech 1 01-01-2007 03:47 AM
Tags
01, ford, mecury, mercury, o2, sable, spark, stable, taurus, taurusno
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
