taurus 2000
I suggest that you familiarize yourself with the starter components before performing any work: 2000 Taurus starter diagram
Let me know if you need any other assistance!
Turn on the headlights and see if they are real bright or sort of dim. If the battery is really low, the lights will come on, but there is not enough current to turn the starter. See if you can get someone to give you a jump to see if it will start. Be sure to hook the cables up properly. Good luck.
