vibration in gas pedal - Ford Forum - Enthusiast Forums for Ford Owners
Thread Tools Search this Thread
Old 04-04-2005, 09:53 PM
Default vibration in gas pedal
I just bought a 2004 Taurus SE, with a 3.0L engine. There is a problem with a droning/oscillating vibration in the gas pedal while driving. The pedal does not vibrate when the it is pressed while the car is in park. Also, the vibration does still occur when the car is coasting in neutral. Because of these points, I am led to believe that it is not caused by engine vibration. The car has been in to the dealership for servicing twice, and both times there was no improvement. The first time, they performed a TSB which called for a different bracket behind the pedal to alter the path of the pedal cable. The second time, they replaced wheel bearings.
If anyone else has experienced this problem please let me know what was done to fix it. Or if you have any advice, that would be appreciated too. Thanks in advance.
Old 04-05-2005, 02:09 PM
Default RE: vibration in gas pedal
I'd suspect the bracket that holds the cable jacket near the throttle body might be loose?
Old 04-05-2005, 03:33 PM
Where is this bracket? Is it right by the throttle? There is a small plastic loop holding the cable but its a foot or two from the throttle, closer to the back of the compartment.
I will give it a look after work today.
Besides that, does anyone else have any ideas?
Thanks.
Old 04-07-2005, 05:51 PM
no luck
Old 04-08-2005, 04:20 PM
Try disconnecting the cruse controll cable at the trottle body see if that helps then trobleshoot from there
Old 04-16-2005, 01:34 PM
My brother has an 04 taurus with 14,500 miles , and it's accelerator has vibration. But his doesn't happen until you reach about 45 mph/50 mph right after you drop into overdrive. Anybody have a clue on this?
Old 05-03-2005, 06:37 PM
The gas pedal pedal vibration is very evident on my 2004 SEL. There are actually two issues. The first is a vibration whenever the engine is running and the gas pedal is depressed and released. It happen all the time the engine is running, but it does not vibrate when the engine is not running. I went to my dealer today and tried several 2004 and 2005 Taurus' - all of them did the same thing. I have tried insulating the accelerator pedal, the pedal mount on the firewall, and the cable bracket on the throttle body. None of these things made any difference.
The second issue appears when the car reaches around 40 MPH and is in overdrive. There are some TSB's addressing this issue as has been mentioned in an earlier post. I have had this work done, and again, it didn't solve anything.
I have to believe that someone, somewhere, knows the cause of this and what can be done to solve it. It is driving me crazy.
Thread Thread Starter Forum Replies Last Post
2009 Escape with vibration in gas pedal Draal Ford Escape 4 11-10-2012 10:11 AM
2012 Explorer Gas Pedal Vibration 1200-1500RPM Nexus Ford Explorer 0 10-18-2011 06:04 PM
gas pedal vibration ford guy Ford Escort 0 05-22-2011 03:31 AM
Vibration in gas pedal ford explorer plittlej Ford Explorer 0 09-16-2009 06:35 AM
gas pedal vibration dtk11 General Tech 3 05-19-2005 05:01 PM
Tags
2003, accelerator, accellerator, engine, escape, ford, gas, pedal, problem, produced, taurus, vibrates, vibrating, vibration, wheel
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
