Ford Tempo/Probe These small cars offered a sporty feel and affordable price.
1989 Probe won't stay running
Old 03-04-2012, 03:09 PM
fiestyfeista's Avatar
Default 1989 Probe won't stay running
I have an 89 Probe that kept cutting out while driving. It finally stopped running all together. I have replaced the distributor cap, spark plugs, fuel filter and fuses. It will start but then won't stay running. Any suggestions what else to try. It is getting power from the starter and to the starter.
Old 03-04-2012, 04:07 PM
We usually need three- four things for the engine to run.
1. Fuel
2. Spark
3. Air
4. The above 3 in the right place at the right time.
The easiest thing to check for is air, make sure the air filter is not plugged.
Then the next easiest is to check for spark.
Then you verify that you are getting enough fuel at the right pressure.
If you are getting the above three the last requires a compression test and most of the time one of the above three could be the problem.
Old 03-06-2012, 05:00 PM
Thanks Hanky, I'll get all these checked out.
Old 03-12-2015, 11:51 PM
beaglerock's Avatar
Sounds like the igniter to me as I had an 89 w / turbo and that puppy will will stop you in your tracks also check the fuel pump relay on the firewall
jkkay
02-24-2021 03:39 PM
Jstew
07-05-2011 02:28 PM
rmcard
12-17-2006 06:30 PM
cruzandkathy
07-30-2006 04:04 PM
chaumer
02-20-2006 03:37 AM
Quick Reply: 1989 Probe won't stay running
