Removing Probe GT Header
Hello,
I recently bought a 94 ford probe GT and shortly after buying it, the flex pipe busted out. So i purchased stainless steel headers and flexpipe off ebay. The front header was easy to remove but does anyone have any tips or give me a place to start with removing the rear header? I really need help with this.
Do i need special tools or to remove the engine. Please help!
you may run into a problem where the header is connected to the rest of the exhaust, it should be connected by 2 bolts and they may be to rusted to remove. if this does happen check out this cool product that i found a couple months ago. it will definitely cut down the time you spend on this project.
http://the-hush.com/
93, flex, ford, forum, gt, header, headers, install, installation, installing, nitrous, pipe, probe, removal, transmission
