1966 T-Bird Landau
Old 08-22-2012, 02:50 PM
Norton-Bird's Avatar
Default 1966 T-Bird Landau
I need to know the bolt pattern for the wheels. Does anyone have specifics for this year?
Thanks, Neil
Old 08-22-2012, 07:38 PM
Most manufacturers usually recommend a star pattern.
Old 08-23-2012, 09:16 AM
I bought a star pattern that I thought would fit but the front disc pad assemply is in the way. Is there a modern equivalent to this part that is more streamlined?
Old 08-23-2012, 12:38 PM
Before we go any further, I believe I misunderstood your question. What I was referring to was a bolt tightening pattern. Now what I think you want is something completely different and this is kinda out of my field of so called expertise. Sorry !
Old 08-23-2012, 06:52 PM
grindman's Avatar
I think he means what is measurements of how far apart is lug nuts for the wheels he's trying to put on Hanky which I think they're 5 on 5 which means that if you stand your wheel up and measure the distance on holes skipping the top one that gives you your bolt pattern on what will fit and what won't
Old 08-23-2012, 08:38 PM
thexlo8ers's Avatar
Thanks, Neil
Here are a couple of links to determine measurements.
MRW - How to measure bolt pattern
Measuring Bolt Patterns - How to Measure Your Rim's Bolt Pattern
Typically the terms that are used to discribe wheel patterns in relation to spacing is, for example: 5 on 4 1/4".
The first number denotes the number of studs and lug nuts. This number is most often a "4, 5, 6 or 8".
The second number is the spacing of the studs and lug nuts.
So 5 on 4 1/4" is five lug nuts seperated 5 and a quarter inches apart (4.25"). Sometimes the spacing is given in milimeters, (mm).
I think you'll find your '66 is a 5 on 4 1/2". But, I'm not 100% positive.
Dooda354
07-22-2009 03:59 PM
ddareaustralia
12-27-2008 04:12 AM
EP103
10-23-2007 08:49 PM
pixleyyy
03-26-2007 04:42 PM
pixleyyy
02-03-2006 09:14 PM
Quick Reply: 1966 T-Bird Landau
