83 T-bird Ac issues
Old 08-27-2010, 03:09 PM
erc004's Avatar
Default 83 T-bird Ac issues
I have a 83 t-bird with AC problems. When the engine is cold the ac blows cold air. After the engine gets hot it blows hot air. The freon is full and clutch is working. Any ideas?
Old 08-28-2010, 08:57 AM
stuart40ca's Avatar
It could be a blend door not closing or opening.
Check for vacuum leaks.
Is the condensor clean?
You mention full of freon, have you had the pressure taken?
Old 09-01-2010, 06:47 PM
erc004's Avatar
Default Blend door
I figured out it is a problem with the blend door opening and shutting on its own. Anyone know how I can fix that issue. A diagram or something?
Old 09-02-2010, 07:16 AM
stuarta's Avatar
If a door is operating by itself that means there is a vacuum leak.
Check the entire vacuum system, the leak could be anywhere.
tdkruse
04-07-2016 01:22 PM
maiden_fan
07-25-2014 06:02 PM
80t-bird
09-24-2012 01:35 AM
dwarber
11-04-2009 12:12 PM
dave00beer
12-01-2006 03:19 PM
Quick Reply: 83 T-bird Ac issues
