'96 T-Bird Flasher Relay Location
Old May 15, 2012 | 06:12 PM
Drag Racer's Daughter's Avatar
Default '96 T-Bird Flasher Relay Location
I have a '96 T-Bird. Neither Turn Signal is working, but the Hazard indicator is STILL working. I've replaced the 10amp Fuse with no luck. My next instinct is to replace the "Flasher Relay"... However, after looking at some wiring schematics I am not certain that there is a single function Flasher relay unit. Instead, I keep seeing information about the Multiple-Function Switch (MFS) which powers & controls BOTH the turn signals and hazard indicator. I can't find a part number or even image of a flasher unit. What's the scoop? If the MFS was bad, it would seem to me that the hazard indicators would not be working on my car...but they are! So....Is there a Flasher relay unit behind the lower dashboard on left side of steering wheel, near the brake area??? HELP! Part numbers, images, or additional schematics would be appreciated! Thanks!
Old May 15, 2012 | 06:14 PM
My T-Bird is a 4.6L, V-8.
Freewalker
May 19, 2012 09:58 AM
troyhay
Nov 4, 2010 04:47 AM
Kav
Aug 19, 2009 07:02 PM
twalters71
Mar 23, 2009 12:50 PM
FiftyFourF100
Feb 7, 2008 10:36 PM
