91 thunderbird fuel pump not turning off
I have a 91 Thunderbird and the fuel pump will not turn off. I looked for a relay to see if that was stuck on but could not find one. If you know where it is please let me know. Thank you.
Mike
Mike
RE: 91 thunderbird fuel pump not turning off
Could also have beenthe distributor mounted ignition module. The switch in the trunk usually doesn't affect continual pumping of fuel - it's an auto accident fuel cut-off switch (therefore it has the opposite purpose only , really). That switch should always be on (in other words) unless you crash or jolt your car badly.
jozepy24
07-13-2019 05:21 AM
fordexpedition2006
04-21-2017 05:23 PM
completemessox
04-30-2008 12:13 PM
