Distributor
Old 02-14-2022, 05:06 AM
Tea bag's Avatar
Default Distributor
Distributor, what's the tube at the base of the distributor called my new didn't come with it
Old 02-14-2022, 05:34 AM
What is this dist for?
Model, size engine, year are all important , unless you can post a picture.
Old 02-14-2022, 05:37 AM
Tea bag's Avatar
78,f150, 300 inline 6
Old 02-14-2022, 05:39 AM
Tea bag's Avatar
Default Distributor
It's on a 78 f150, 300 inline 6
Old 02-14-2022, 05:54 AM
Without a pix, not sure.
Is this the vacuum advance unit that is held on to the side of the dist?
Old 02-14-2022, 05:57 AM
Tea bag's Avatar
Default Distributor
Yes,it is
Old 02-14-2022, 10:04 AM
OK, then all you need to do is, remove the clip that holds the arm from the vacuum advance unit,, then remove the 2 screws that hold it onto the dist and now install that unit on the new dist.
3 steps, install 2 screws, connect the arm to the pin , install the retainer clip , and you are good to go.
Did you mark anything so you get the dist in correctly ? If not, unless you know EXACTLY what to do, you could get into deep waah- noo na !
That dist tells the plug when to fire and if that is not set correctly on installation , the wrong plugs could get the spark to fire at the wrong time and the engine may not even start and could backfire out the intake or exhaust.
RacingRoger
04-02-2021 10:13 PM
camshaft01
12-24-2008 03:16 PM
trex66
02-10-2007 10:07 PM
barkerjoe
11-17-2006 11:19 PM
blue_streak
04-08-2005 03:24 PM
Quick Reply: Distributor
