2005 6.0 will not crank after routine fuel filter change
I have changed my fuel filters for the second time on this truck and now it will not crank. is there another way to get the air out of the system? I have tried cranking and turning the key back and forth for the last two hours. I need my truck please help
RE: 2005 6.0 will not crank after routine fuel filter change
Will not CRANK (as in turn over)or will not START (as in turns over but doesn;t fire)? If it turns over but doesn't start, you can bleed the system by turning the key to the ON position. Then go to the shrader valve on the fuel rail, take the cap off and push in on the center bleed valve until all air is gone. Remember, the fuel willcome out underpressure.
Transit04
05-03-2013 10:25 PM
cervin
08-10-2007 08:44 PM
