Pioneer/Clarion nav radios
Old 01-12-2012, 09:23 PM
muthastone's Avatar
Default Pioneer/Clarion nav radios
If I have a 2009 Ford Escape, would I have the option to put either a Pioneer/Clarion navigation OEM radio in my vehicle?
Will either be able to be programmed to my car?
Old 04-04-2012, 09:41 AM
DMarafino's Avatar
For a 2009 Escape, you will need the Xanavi/Clarion HDD Nav.
You will also need the following to complete the install assuming your car has SYNC:
Replacement Right side steering wheel control
Antenna Splitter
Extender Cable
Amplifer
Amplifier Harness
Procedure 1 & 2 Harness with Sync Pins (available from United Radio)
United Radio sells everything you need as a kit, and can also program the vehicle to your vehicle.
You will also need a new dash bezel that comes from the ford dealer.
Old 04-09-2012, 06:28 PM
Leesmith's Avatar
Default Ford sport trac radio
I have a 08 sport trac adrenalin. It does not have the navigation radio in it. It does have micro soft sync and blue tooth and 6 disk cd. I was wondering if I can put an 09 explorer ford navigation radio in it and will it work.. Ford dealer is absolutely no help...
Old 04-10-2012, 07:43 AM
DMarafino's Avatar
You may be able to put an 09 radio in, but it's not meant to be put it that car and you may run into a lot of compatibility issues with SWC & Sync. Also the 09 will require an external amp.
I would recommend just putting the 08 Pioneer Nav in, like what would have came with the truck. All you'll need is an 8A2T-18K931 nav unit, Map, Antenna, and have the unit programmed to your vehicle.
Old 04-18-2012, 09:46 AM
muthastone's Avatar
Antenna Splitter
Extender Cable
Amplifer
Amplifier Harness
Great. So I wouldn't need any programming done? We also have a 2012 Escape. How would that work?
We have 2 units on us right now. part numbers are AL1T-18k931-AE and CC3T-18k931-AA
Old 04-18-2012, 09:49 AM
DMarafino's Avatar
The CC3T is for a superduty, but should work in the 2012 Escape. The AL1T is not meant to work in an 08. Any factory NAV unit you put in a car will require programming to the car in order to work.
Old 01-31-2013, 09:59 PM
sdgale's Avatar
Default 2011 nav
Do you have a oem nav for 2011 superduty? Please let me know.
Cook
09-26-2012 10:04 PM
muthastone
01-12-2012 09:21 PM
Valik
04-19-2007 11:21 AM
sensomage
03-01-2006 01:07 AM
HotRodderx
09-21-2004 02:44 PM
Quick Reply: Pioneer/Clarion nav radios
