94 E250 fuel delivery problem
Old 04-12-2007, 01:42 PM
mondotto's Avatar
Default 94 E250 fuel delivery problem
Have posted questions before, thankful for this forum.
I just towed a friends E250 back to his shop. We have determined that the fuel pump operates when the key is turned from off to on but when you crank to start it stops pumping. Any advice would be great, thanks.
Old 04-20-2007, 10:09 AM
Default RE: 94 E250 fuel delivery problem
was this truck in a accident? if so id check the inertia shut off switch. also things to look into, the fuel pump relay itself. another thing is check for a faulty oil pressure sending unit. i have heard if there is a bad oil pressure sending unit or no oil pressure at all it will shut the fuel system down so that it wont start and run with no oil. hope you guys get it figured out good luck..
budweiserburton
11-07-2013 10:25 AM
zx2_2001
12-29-2010 03:07 AM
Larry607
01-05-2010 11:33 AM
bevis28
10-06-2005 02:50 AM
REAPER1987
09-01-2005 01:41 AM
Quick Reply: 94 E250 fuel delivery problem
