ball joints on 02 sport-trac
Old 07-04-2005, 05:50 PM
coachpelkey's Avatar
Default ball joints on 02 sport-trac
What an awesome place to ask questions...I have an 02 sport-trac 2wd...50k miles on it. Last year when I was getting inspected, they said in a year I would need to get new ball joints. How do I know I would need them, and if I do how much should they cost installed so I know I am not getting beat up about it..
ryanpelkey@hotmail.com
Thank you[8D]
Old 07-12-2005, 05:04 PM
Default RE: ball joints on 02 sport-trac
Well, lets start by how they are inspected. Generally, inspecting these requires jacking up one front side at a time from the frame and putting a LARGE prybar under the wheel as it is inches off the ground and proceeding to load the suspension with the pry bar thus simulating the load encountered by your car during regular use. this usually involes having a second person helping to listen to or even feel the ball joints for signs of popping or play. Now, the shop that said this may have heard a slight noise last year which may or may not have been the ball joints, these tests can often be misleading, especially if they only heard slight noise. 50,000 mi. is a bit early for such a problem, especially on a 2wd. Have it checked again. if it indeed needs them, expect to pay between 450$ and 750$ out the door. But do have someone check again.
Old 07-12-2005, 05:17 PM
balljoints have to be measured there is a spec on them even if there is some slack in the balljoint doesnt mean they are done measuing with a dial indicator.and is common for lower balljoints at or arounf=d your mileage and price is what you want back on there ford parts aftermarket and where it is repaired.
Towguy76
05-22-2013 12:01 PM
e250extended
12-24-2007 12:32 PM
crs5357
06-16-2005 11:21 AM
harleybadboy2
06-03-2005 09:51 PM
oldschool1
11-08-2004 12:25 AM
Quick Reply: ball joints on 02 sport-trac
