A/C Compressor Clutch Replace ??? Part 2
Old 06-01-2008, 11:11 AM
chemoman's Avatar
Default A/C Compressor Clutch Replace ??? Part 2
Is this how to link pretty much the same for my 00 F250 5.4L.
http://autorepair.about.com/library/faqs/bl168i.htm
Old 06-02-2008, 04:37 AM
Use Common Sense's Avatar
Default RE: A/C Compressor Clutch Replace ???
Yep, the link pretty much covers it. In case you didn't know, you don't need to pull the compressor to replace the clutch.
Old 06-02-2008, 07:29 PM
Davetheslave's Avatar
Did you fix your clutch maybe that is what is wrong with mine.
Old 06-04-2008, 08:58 AM
chemoman's Avatar
ORIGINAL: Use Common Sense
Thanks. I wasn't sure about having to remove the compressor, but I always try the easy way first. That's just the kinda lazy guy I am.
And
No, I haven't done it yet. I was waiting until it got really good and hot here in DFW so I can get a good sweat going. I'll do it Saturday and post up how it went.
Old 06-04-2008, 05:57 PM
Is and or was your clutch spinning?&nbsp\\; Hey, it would be cool if you did a video of changing it.,
Old 06-07-2008, 12:13 PM
chemoman's Avatar
I'm stuck! I got the clutch plate, pully and bearing off fine, but this thing is kicking my tail!
It must come off because there's a new one in the box with the rest of the assembly.
Any help would be greatly appreciated.
http://i225.photobucket.com/albums/d...clutch0015.jpg
http://i225.photobucket.com/albums/d...clutch0016.jpg
Old 06-07-2008, 04:41 PM
chemoman's Avatar
Well, I had about 25 minutes of how too with pics attached. Clicked "OK" and got some stupid error message that the page cannot be displayed. What a crock!
Oh well, I'll try again later.
Here is my other Ford
http://i225.photobucket.com/albums/d...clutch0025.jpg
Old 06-09-2008, 10:43 AM
Default RE: A/C Compressor Clutch Replace ??? Part 2
The coil is a tight fit on the shaft. Age just adds to the fun. it may need a little coaxing from a couple of screw drivers or small pry bars. Sometimes a puller with small "J" hook jaws works well. Don't forget to gauge your existing shims for proper re-install clearance. This will ball park you for the new ones for proper clearance between the clutch face and pulley. I try to stay between .015 & .030 thousands. Good luck
Frank J. Reda
07-28-2015 03:24 PM
markf1971
07-28-2014 11:57 PM
kfederig
10-17-2009 10:47 AM
TYLEE826
06-12-2008 02:58 AM
Quick Reply: A/C Compressor Clutch Replace ??? Part 2
