Can you replace rod bearings without removing engine just the oil pan?
Old 04-07-2007, 02:42 PM
kingmast's Avatar
Default Can you replace rod bearings without removing engine just the oil pan?
can you replace bearings just by removing oil pan and or what can you get to through oil pan? Is this a typical problem? rod bearings?
Old 04-12-2007, 01:33 PM
Use Common Sense's Avatar
Default RE: Can you replace rod bearings without removing engine just the oil pan?
If you can get the oil pan completely out of the way, then YES you can replace the rod bearings without pulling the engine. However, if your rod bearings are bad, then you problably havea crankshaft that should be resurfaced. Thus the engine needs to come out anyways. Unless your just going to put new bearing in and pawn the vehicle off onto an unsuspecting victim.
Old 04-20-2007, 09:33 AM
If the damage is bad enough you will need to have crank turned as already mentioned, but also if you do go ahead and take the engine out and do get crank turned you may want to look into haveing connecting rods resized as they may be mishaped too if the bearing is damaged bad enough or if it has spun. also be sure to use your plasti gauge before installing the main or rod bearings to check oil clearence.
jcasaccio
10-07-2018 08:02 AM
mike 96 ws6
07-20-2011 11:17 PM
tjent8
06-12-2009 01:50 AM
kingmast
04-07-2007 02:16 PM
kingmast
04-07-2007 02:16 PM
Quick Reply: Can you replace rod bearings without removing engine just the oil pan?
