2005 F350 V10 problem
I just bought 2005 F350 2 months ago. Ran great til it had a bad hesitation and low power. Engine light then came on. Checked code--something about a misfire. Cleared the code, light was back on before I got back home from parts store. Took it to the dealer, they replaced the fuel pump under warranty, also replaced the fuel filter. Now the hesitation is back and light is back on. Truck has 8100 miles on it and all I've done is change oil and put a K&N filter in it. Anybody have the same problem? what was the fix?
HTH ...
This car uses COP (coil on plug), so go to the specific clyinder. For example, a P030x means "misfire in clyinder x". And don't worry, this is a OBDII code, which means there are up to like 16 clyinders that could be missing. Once you locate the specific clyinder, then do a base compression check to make sure the compression is where it should be, then possibly check the fuel injector (it should be clicking rhymically, easily heard with a stethoscope). Take a look at the plug; How does it look? If soaked in gas, look at the injector to be stuck on. If coated w/oil, then go deep into the engine.
bosanci28
04-17-2010 11:33 PM
