Fuel guage sensor.
Old 07-18-2006, 02:36 PM
dawgy's Avatar
Default Fuel guage sensor.
I have a 2005 F-350 PS dually and have noticed over the last month that when I fuel up, it takes a good half hour to an hour for the fuel guage to register full. It starts out at 1/4 full and then begins to very slowly creep up. Any ideas?
Old 07-18-2006, 03:09 PM
techmanbd's Avatar
Default RE: Fuel guage sensor.
Could be the float mecahnism. If it is a 2005, shouldn't it be under warranty? I would take it in for a warranty repare.
Old 07-20-2006, 03:05 AM
Is the truck running when refueling or is the key in the on position when refueling?I have a ford car that will do the same.What i do (after refueling)is shut the car off and restart to get a accurate gauge reading.
Old 08-01-2006, 02:25 AM
Fuel Gauge
05/F350
The instrument cluster receives the fuel level signal from the fuel level sensor, part of the fuel pump module. The fuel level sensor measures variable resistance in the fuel tank depending on the current fuel level. When the fuel level is low, the resistance in the unit is low (15 ohms ± 2 ohms). When the fuel level is high, the resistance in the unit is high (160 ohms ± 4 ohms).
The instrument cluster uses 4 different operating modes to calculate the fuel level:
Anti-slosh (default mode)
Key OFF fueling
Key ON fueling
Recovery
After a fuel fill up, the time for the fuel gauge to move from empty (E) to full (F) ranges from 2 seconds to 55 minutes depending on which operating mode the fuel gauge is in.
The default fuel gauge mode is called the anti-slosh mode. To prevent fuel gauge changes from fuel slosh (gauge instability due to changes in fuel sender readings caused by fuel moving around in the tank), the fuel gauge takes approximately 55 minutes to go from empty (E) to full (F).
The key OFF fueling mode (2 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The key must be in the OFF position when refueling the vehicle.
At least 15% of the vehicle's fuel capacity must be added to the fuel tank.
The instrument cluster must receive a valid key ON fuel sender reading within 1 second of the key being put into the RUN position. The key ON sample readings are considered valid if the fuel sender reading is between 15 ohms ± 2 ohms and 160 ohms ± 4 ohms. If these conditions are not met, the fuel gauge stays in the anti-slosh mode, which results in a slow to read full (F) event.
The key ON fueling mode (approximately 90 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The transmission is in PARK (P) (automatic transmissions), or the parking brake applied (manual transmissions).
The key is in the RUN position.
In key ON fueling mode, a 30 second timer activates after the transmission is put into the PARK (P) position (automatic transmissions) or when the parking brake is applied (manual transmissions). When the 30 second time has elapsed and at least 15% of the vehicle's fuel capacity has been added, the fuel gauge response time is 90 seconds to read from empty (E) to full (F). When the transmission is shifted out of PARK (P) or the parking brake is released, the fuel gauge strategy reverts to the anti-slosh mode. This mode prevents slow to read full events from happening if the customer refuels the vehicle with the key in the RUN position.
Recovery mode is incorporated into the instrument cluster strategy to recover from a missing fuel level message during a refueling event. Missing fuel level messages result from intermittent opens in the fuel sender or its circuits. Recovery mode (empty [E] to full [F] approximately 20 minutes) is initiated when the following 2 conditions are met:
The instrument cluster is in the anti-slosh (default) mode.
The actual fuel level in the tank is greater than what is being displayed by the fuel gauge.
......................HP.............
jtravis75
04-06-2011 11:32 AM
300mag-hunter
08-28-2009 02:26 AM
TAZ454
12-04-2008 09:03 PM
bazuka
01-09-2008 03:08 PM
mkfarnam
04-12-2007 03:07 AM
Quick Reply: Fuel guage sensor.
