Ford Enthusiast Unofficial Resource
Go Back   Ford Forum - Enthusiast Forums for Ford Owners > General Ford Forums > General Tech
Sign in using an external account
Register Forgot Password?
Search
Welcome to Ford Forum!
Welcome to Ford Forum,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread
Old 12-29-2007, 06:38 AM
Default How 2 Program Ford Ignition Key
Hi, i need 2 get a new key 4 my sons '01 focus .I read an article about being able 2 program them yourself ? ,will this work 4 fords ? thanks 4 any info ,,,,,
Introduction Just bought a new Pacifica and want to add another Sentry Key but don't want to pay the dealerships $100 to program it? I will show you how easily you can do this yourself.
This process works for a 2007 Pacifica but might work with other new Chrysler products as well. [/align] Instructions Difficulty: Moderately Easy [/align] Things You'll Need[*]Two Sentry keys that work[*]2007 Pacifica[/ul] Steps 1[/align] Step One Obtain the blank Sentry Key(s) that need to be programmed. Cut the keys to match the ignition lock cylinder mechanical key codes. [/align] [/align] 2[/align] Step Two Insert one of the two valid Sentry Keys into the ignition switch and turn the ignition switch to the ON position. [/align] [/align] 3[/align] Step Three After the ignition switch has been in the ON position for longer than three seconds, but no more than fifteen seconds, cycle the ignition switch back to the OFF position. Replace the first valid Sentry Key in the ignition lock cylinder with the second valid Sentry Key and turn the ignition switch back to the ON position. The second valid Sentry Key must be inserted within 15 seconds of removing the first valid Sentry key. [/align] [/align] 4[/align] Step Four About ten seconds after the completion of Step #3, the indicator light will start to flash and a single audible chime tone will sound to indicate that the system has entered the "Customer Learn" programming mode. [/align] [/align] 5[/align] Step Five Within sixty seconds of entering the "Customer Learn" programming mode, turn the ignition switch to the OFF position, replace the valid Sentry Key with a blank Sentry Key transponder, and turn the ignition switch back to the ON position. [/align] [/align] 6[/align] Step Six About ten seconds after the completion of Step #5, a single audible chime tone will sound and the indicator light will stop flashing and stay on solid for three seconds and then turn off to indicate that the blank Sentry Key has been successfully programmed. The SKIS will immediately exit the "Customer Learn" programming mode and the vehicle may be started using the newly programmed Sentry Key. [/align] [/align]
Old 12-30-2007, 06:36 PM
Default RE: How 2 Program Ford Ignition Key
Why would you think a procedure from another manufacturer would work? Unless you have two keys already programmed, you will have to have a dealer or locksmith with the proper equipment to program the new key.
__________________
Dennis W
www.blueovaltechs.com
http://blueoval.myminicity.com
Old 12-31-2007, 06:29 AM
Hi Dennis ,, thanks 4 reply , yes it might b a chrysler procedure , but wanted 2 know if ford ,or any other co's might also do it this way . was leaning more 2 an electronic programing procedure ,,not a model type . ,,keith ,,,
Old 01-11-2008, 10:00 PM
The instructions to program additional keys is in the owners manual
Old 01-15-2008, 12:01 AM
The Key has to be programed by a dealer. While your at the dealer you can ask them to enable customer spare key programming.
Old 01-22-2008, 02:12 AM
The procedure is exactly the same as chrysler , if you have two programed keys you can program up to 8 keys just the same way . if you only have one programed key you have to taked it to a dealer so the can access the p.a.t.s. and erase the existing key then program the two keys buy cycling the keys the same way .
Old 01-23-2008, 12:42 PM
If you already have two keys that are programmed, then you can program the rest yourself, up to eight keys. If you only have one key programmed, then the dealer is the only one that can do it, or a locksmith with the right equipment. Whick is it?
__________________
Too Old to Work, Too Young to Die.......GO fishin'
35 Years with Ford
ASE Master
Ford Engine Master
L1
Old 01-23-2008, 12:50 PM
if you only have one key the dealer has to do it beacuse you need thier I.D.S. system to access the p.a.t.s. and delete the key from memeory then reprogram 2
Old 03-01-2008, 03:20 PM
every key for a ford ignition has to be programed with a wds or an ids you can have upto 8 keys programed but everyone of them needs to be programed at a dealer no way around it unless you have a way to break into the pats system
Old 03-02-2008, 02:03 PM
no you don't if you already have 2 programmed you can program up to 8 buy cycling the key you don't need to get in to the pats !
Tags
01, 2007, escape, expedition, explorer, focus, ford, iginition, ignition, key, keys, pats, program, programming, ranger
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Our Sponsors
New Sponsors
© Internet Brands, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
SEO by vBSEO ©2010, Crawlability, Inc.
