loose steering
loose steering
wondering if anyone can help...I have a 2002 explorer sport the steering on it feels very loose and it jumps around when I hit bumps or even road dots... I have just put 20 inch wheels on it and also have put new bearings/brake caliper.brake pads.rotor. & also new outer tie rod end. but steering it still still. due I need to due hieght adjustment or is there a way to tightn steering or is it just an alignment..any help would be appreciated...thank
RE: loose steering
It's possible that you have bad shocks. Also, don't forget that the size of the tires that the manufactures put on a vehicle are BUILT INTO the suspension and how it handles. Since you said that it was doing it before hand, I would replace the OEM shocks with a set of Monroe REFLEX shocks in all 4 corners. They'll help give you that STICK TO THE ROAD feel.
rebar
05-12-2013 04:11 PM
