Rough idle and engine stalling
Old 03-17-2012, 12:18 PM
Tx-fordguy84's Avatar
Default Rough idle and engine stalling
I have a 2006 f150 4.6, a couple weeks ago the code came up for the fuel cap so I replaced it, then yesterday it came back on and it also had a code for a vacuum leak. I found a hose from the fuel tank to the evap canister that was unhooked so I put it back. Now my truck barely starts and won't idle, it spits and sputters and then dies if accelerator isn't constantly pushed. The new code it's throwing is p2196. Any help would be greatly appreciated
Old 03-17-2012, 04:40 PM
greasemark's Avatar
A P2196 means the O2S11 sensor (pass side, first in stream) is stuck rich, and even when EEC compensated, it could not get the o2 to switch or go lean.
These trucks had all sorts of problems with fuel injectors sticking open or closed, which was covered under a recall years ago (which may still be applicable to your truck, depending on milage/age; you'd have to call a dealership for them to enter the VIN and check it). This (in your case, if it is) would be a stuck open injector, which would cause a hard start (sometimes slow to turn over from hydrolock) and black smoke out the exhaust, as well as fouled plugs. And if it goes on for a while, a worn out (or melted) catalyst and posssible engine damage (I've put a few engines in for this condition, which did start as a defective fuel injector).
Start with someone doing a full fuel system check, and for presssures and the ability for the system to hold pressure with no leakdown. If there is leakdown, that could be a sign that something is bleeding down.
Possibly if you could watch the power balance, then you could identify which clyinder(s) are affected by watching the power output. It should be relatively smooth without any deep peaks.
If this is running that rich, then make sure to change the oil when repaired to get the contaminated oil out of the engine.
alossofthought
08-13-2013 06:17 PM
Videoguybob
08-16-2011 08:19 PM
Olpapa
05-18-2008 03:22 PM
whitacre06
04-27-2008 09:19 PM
SWDina98escort
11-08-2006 12:23 AM
Quick Reply: Rough idle and engine stalling
