2004 Freestar rear heat help please
Old 11-28-2010, 03:49 PM
freestar man's Avatar
Question 2004 Freestar rear heat help please
I have no rear heat in my '04 Freestar. When you activate the switch, front or rear controls, I hear the relay click but the motor does not spin. I put twelve volts direct to the motor and it works perfectly. I have voltage at the plug to the motor as well. I tested the relays and they are good. I also tested the resistor and it checks out. I swapped and replaced the relays and swapped in another blower motor just to see. Nothing changed. If you switch to A/C I hear the flapper door switch positions. The front works perfectly. Can anyone help me figure this out? Thanks
Use Common Sense
06-25-2016 01:30 PM
Mike Lightous
10-30-2013 10:14 AM
alex5357aa
08-09-2013 12:15 PM
No_Oneq
05-27-2013 12:28 PM
mssief
03-24-2013 12:35 AM
Quick Reply: 2004 Freestar rear heat help please
