I could use a bit of help
Old 06-22-2016, 11:24 AM
grindman's Avatar
Default I could use a bit of help
I am working on a 02 mercury mountaineer and the owner of the thing and they're scared to death when they driving it, saying that it's making a scraping and popping noise and I can't hear it or get it to make the noise so that I can fix it. The engine is a 4.0 V 6 with the auto transmission and to top it all off it is all wheel drive. Any help as to what they're worried about would be greatly appreciated
Old 06-22-2016, 12:28 PM
Shay_Fox's Avatar
Well i don't know what to say. May be someone ??
Old 06-22-2016, 07:21 PM
Hi Grindman !
I don't know the answer to your request, but since you can't get it to make the noise when you drive it maybe if you have them drive it with you in the vehicle they might be able to make it happen. Those 4.0 L. engines were noted for timing chain problems and some of the engines had to be pulled to repair the rear chain parts. Not really one of Ford's better ideas. What do you think ?
Old 06-22-2016, 07:51 PM
grindman's Avatar
Hi Grindman !
I have had them drive it with me as the passenger and it won't do it at all. I am beginning to think that there's no need to worry about it and drive until the something breaks and I might be able to get the thing fixed.
Old 06-23-2016, 07:12 AM
LakelandFordParts's Avatar
Former Sponsor
I was going to suggest front end/suspension issues but those sounds would be very easily duplicated. Good luck!
Old 06-23-2016, 08:23 AM
primem's Avatar
if you can't duplicate the noise do not even try a repair....it would be guess work.
either have them leave the vehicle with you for a couple days with a description of the conditions necessary for the noise to happen or have them return when the noise is present.
A suspension check for obvious worn parts is a good idea.
Old 09-09-2016, 09:41 AM
grindman's Avatar
Well I got it fixed and it turned out to be the rear knuckle on both sides . I haven't heard from them since I changed them out. So I guess no longer a problem with it.
Old 09-09-2016, 09:54 AM
No news, is good news. 👍
Old 01-28-2017, 01:34 PM
grindman's Avatar
Well I have a different vehicle that I could use some advice on. I am working on a 2005 mercury grand marque 4.6 engine doesn't matter the mileage on this one because some how it won't let me take it out of park after I replaced the module for the headlights. I was able to move the gear selector after replacement of the steering column. And this is what's got me puzzled. It starts up with no issues but, I still can't get it out of park. Any idea would be greatly appreciated
Old 01-31-2017, 09:45 AM
Use Common Sense's Avatar
Have you checked the brake safety (interlock) switch by the brake pedal? Maybe not getting a signal to the tranny.
hubbard85
07-03-2018 09:31 PM
BigBlack302
07-08-2012 01:05 PM
chad91f350
10-30-2010 02:12 PM
BrownVicdude
11-27-2007 07:34 AM
Quick Reply: I could use a bit of help
