Check Engine light questions
Old Dec 11, 2007 | 11:05 PM
mexiburger's Avatar
Default Check Engine light questions
I have a '92 F150 with a 302, the check engine light comes on if it is allowed to idle and in slow city driving. The engine seems to continue running fine but I would like to find out what causes this. I dont have a code reader, so is there anything I should check to start tracking this down?
Any help is appreciated.
Old Dec 11, 2007 | 11:17 PM
Default RE: Check Engine light questions
Having the code first would be a big help.. Some of the parts vendors like Autozone ect. can read the code at no cost..
Old Dec 11, 2007 | 11:52 PM
mexiburger's Avatar
Thanks for the reply.
I suppose the code would only show up if I had it read whyle the light is on right?
Old Dec 12, 2007 | 10:27 AM
Bullitt94's Avatar
No, the computer will store the code and it will be read when the codes are pulled.
My '90 has similar symptoms, too. It came back with an oxygen sensor code and an EGR code. Both are pretty common with check engine lights.
Old Jan 29, 2008 | 01:37 PM
Frordtrucker's Avatar
Where can the code reader terminal be found on a 1993 F150 5.0? My check engine light comes on after about 3-4 miles of driving. PCV valve is fine, and K&N filter juast serviced. Thanks for any help.
Old Jan 30, 2008 | 08:49 AM
Bullitt94's Avatar
Look on the driver side under the hood. I should be on the side of the fuse box (from my memory it is a fuse box). It is easy to find if you know what you are looking for.
93redxlt
Mar 18, 2010 04:44 PM
allensimpson
Jan 10, 2008 09:40 PM
farris1307
Sep 9, 2005 04:59 PM
basketbjones
Aug 30, 2005 10:16 AM
bluemq1
May 16, 2005 08:06 PM
