Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
HELP HELP HELP
Old 10-21-2007, 01:53 AM
jborushko's Avatar
Default HELP HELP HELP
i dont have that fantcy tool to measure how many spacers i need to toss between the pinion and pinion bearing in my 8.8 rearend any tips or cheats i can use?? please help!!
Old 12-22-2016, 08:06 PM
Jammins's Avatar
If you take grease and put on pinion gear and rock back and forth main gear will leave a pattern and look at any book that talks drive axles it eill show what pattern u need and add or remove as needed.
