5r55s rebuild
Old May 12, 2013 | 07:45 PM
Ducalion's Avatar
Default 5r55s rebuild
Hi,I have a 2004 explorer that had the rev. and forward not going in to gear unless you reved up the motor. so I tried the fixes that every one on line suggested...1st I puled the pan and checked the reverse piston,then I puled the solenoid block and tested the circuits and each solenoid,when I pulled the reverse piston I saw a very small piece of flat copper like a washer maybe,,,,so I went ahead and pulled the tranny looking for what was being shredded in there. well I've got it all apart and found a couple more small pieces in there,I think it was a copper or brass washer above or below one of the planetary gears since i can't find any other parts the same material....but there are no sings of ware on any parts,so any suggestions on what else to check?
makuloco2000
Aug 19, 2014 11:20 AM
makuloco2000
Nov 11, 2013 09:51 PM
makuloco2000
Nov 11, 2013 09:30 PM
79Bronco
Mar 30, 2006 10:51 PM
Fastronald
Sep 4, 2005 08:51 PM
