Ford Aspire Check Engine Light - P0130
Hi
I have a Ford Aspire 96 2 door hatchback. Just bought it around 1/2 year ago and the "check engine light" came up in March. Brought it to a mechanic and they scanned and found the code to be P0130. They recommended changing of oxygen sensor which I did. In April, the same problem recurred. I checked with the previous owner and he mentioned that it is a recurring problem and he has changed the oxygen sensor 3 times during the single year he owned it. Brought the car back to the same mechanic for a more detailed check, and this time they found the exhaustive pipe between manifold & catalyic conv. to be defective (leaking). I brought the car to a muffler shop to repair the leak. Seems okie for 1 month but now the light is on again, same code P0130. I am really a newbie, new driver with little mechanic knowledge, first time owner car. I am getting real frustrated with the problem and also a bit concerned .. i) Any recommendation on what could be the real problem? ii) Is it okie if I just ignore the problem? I have my friend resets the code and it seems to come on after 2 weeks (seems to come on every time I top up gas) Forgot to add, the engine and car runs well. Cheers An anguish & helpless owner |
RE: Ford Aspire Check Engine Light - P0130
Did you replace both oxygen sensors? There are two on the vehicle, an upstream by the manifold as well as downstream by the catalytic converter.
Also a clogged converter could confuse the computer and make it run bad.
