03 excursion radio problem
i just pulled my radio out of my 03 excursion and when i put it back in all the features worked except for the 6 disc CD . i get a CD error when i try to access the CD feature. i can not eject the CDs either. is there a reset or somthing that needs to be done or something? thanks
RE: 03 excursion radio problem
Did you plug everything back in correctly? Sounds like something is disconnected. Try disconnecting the ground wire on the battery for a couple minutes to reset everything.
You may have bumped something a little too hard. Those units are extremely sensitive. Most of them have a sticker on the top of them that says "Scrap if dropped"
your cd mechanism is jammed and these are not cheap to repair I work for a audio shop here in florida and those at my cost are about $395.00 to refub entire unit at a flat rate fee.good luck,Tim
I have that problem now with my fav cds in there does any one know how to get the cds out so I can scrap this piece of junk.
