speakers?
i want to put subs in my ranger standard cab and i dont know what will fit. i drive with the seat all the way back or it is uncomfortable. any suggestions?
RE: speakers?
Check out www.crutchfield.com You can enter what car you have and they will have vehicle specific items.
MTX sells something that will fit a 10" sub that fits in the passenger side. |
RE: speakers?
Also, don't know what you are looking to do, but this is a cool combo. Infinity Basslink T. It has the amp in it and can be mounted agoainst the back wall. Check the description to see if it would work for you. They also have the Infinity Basslink and Basslink II
BASSLINK T http://www.crutchfield.com/S-NBOPww6...00&I=108BASSLT BASSLINK http://www.crutchfield.com/S-NBOPww6...0&I=108BASSLIN BASSLINK II http://www.crutchfield.com/S-NBOPww6...0&I=108BASSLN2 BASSLINK II w/ MODULE http://www.crutchfield.com/S-NBOPww6...0&I=700BASS4CH I plan on putting the Basslink II with the module in my mustang. I am looking for good clean sound. Not looking for overly loud bass thumping |
RE: speakers?
I know where you are coming from. It depends if you know anyone that builds custom enclosures or not. I but a Kicker Solo-baric L7 8" behind the passenger seat, and used the room behind the driver seat to add airspace. It is all connected with a flat section that is a little bit wider than the armrest so my seat sits all the way back and the passenger seat is only up one notch. If you want to go a dfferent way, I installed a set of Rockford Fosgate 8"s in 2 of my buddies trucks. The only thing about 8"s is that they need to be in a small box to get that hard hit. As for going to crutchfield to get your stuff, that is up to you. In my experience, ive found that Crutchfield is normally overpriced. Ive ordered several speakers because me and a friend build the custom enclosures where I live. All of my stuff, I order from www.ikesound.com or www.uscaraudio.com. They are really good sites, especially ikesound, and they can save you a lot of money. You may want to shop around before you commit to anything, but you can have some good sounding systems out of a Ranger.
RE: speakers?
contact Phil at www.woodlawncabinetry.com he will build you an awesome enoclosure that is built for your vehicle and for the speaker. I would also look at www.edesignaudio.com for some awesome subs, I think they are releasing a shallow mount 10 that would be perfect for your application
