1992 EFI 460 swap
I have a 1992 EFI 460 that i'm wanting to convert to carb and standard hydraulic cam. Is the cam swap possible and what all would be involved besides the obvious lifter change. Is it possible to install a performance cam and use the existing factory lifters if so how big ? I'm swapping this 460 into a 1966 galaxy that currently has a 289 what motor mounts can i use and where can i find them also will i need to swap out the transmission cross member for the bigger c-6 trans. All information on this topic will GREATLY be appreciated.
Viperman_72802
Viperman_72802
