1967 Country Sedan Fuse Location
Hello All: I'm looking for my fuse box for my headlights. Anyone know where to start? I looked under the dash and in the engine area.
Thanks |
there is some fusable links located on the solinoid by the battery. I bet one or more is gone bad. Welcome the sight
If after you find the power source and find everything is OK, I believe the older headlight switches had a built in circuit breaker just for the headlights alone.
If you could not get power to the headlights you had to replace the switch. |
Thank you both. I'll check them both out in order. Power first then cb in the switch.
breaker
Right on the battery terminal as mentioned. Thank you
you're welcome. glad you got it fixed.
