72 Torino problems
So I've been working on this car for a couple months now, it has the 351M in it. So this is what I've done so far,
Edelbrock Intake Edelbrock Carb *600* Edelbrock Cam *mild street cant remember the duration* Edelbrock double roller timing chain Mallory HYFire 6AL Ignition box Mallory HEI distributor here is my problem, I cant get the damned car to time. it will either idle around where it needs to be and then drop off after you tap the gas, or it will idle so high that when you plug in the vacuum line it idles even higher. I am totally stumped with what to do with this thing now. PLEASE, and ideas would be great. Thanks in advance, Austin, Also, if you live in So Cal, i can use the help..... |
| All times are GMT -5. The time now is 03:37 AM. |
