FordGalaxie885 |
05-28-2013 08:27 AM |
Ford Galaxie 302 making ticking noise?
My 1969 Ford Galaxie 500 302 V8 has a slight problem. I have tuned it and everything it runs great, but theres a noise thats slightly worrying. While running theres a loud ticking noise. Loud to the point where I can hear it on the highway. And it seems louder on the highway than it does on regular roads. It is definately part of the engine as it speeds up as the cars speed does.
I had one idea on what it could be. I have a hunch that the valve seals/seats (if those are the same thing) are going bad. There is a significant amount of oil on the spark plugs from inside the cylinders. Im also pretty sure it has bad piston rings but I know the valve seals can have the same oil effect.
Suggestions? Ideas? I mainly want to fix the ticking for now. I know it can become a problem eventually. When I start my new job in a couple weeks I will probably replace the valve seals anyway but I want to try and pinpoint this problem!
