Heater box
One day
Anyone who has a 62 Galaxie or the associated wagon and has removed the Heater box, is there something I'm missing.. The manual says to remove the retaining nuts.. I see no retaining nuts the heater box sits on the sound insulation as far as i can tell.. I know I need to remove the hoses. But I'm talking about taking the heater box out... What did you do!!!! Just so we don't have a miscommunication. this is up under the dash under the glove box and radio... Best Dave |
heater
OK, so I should have "thought" and looked at the firewall..
the heater box has studs that push through the firewall and speed nuts are used on the engine side.. So now you know the rest of the story!!!! Best |
Most are that way,, although they like to sneak a hex sheet metal on occasion from the interior. More so GM.. Or hide one behind the inner fender ...
I'm just glad I "thought" to look...
I just need to move it so I can put in the new floor pan... and of course while it's out, I'll do a little cleaning, de rusting of a few parts I see... maybe some fresh paint.. Best |
update..
The clove box needs to come out... there are 3 cables One on the front, One on Top and one on the backside... also there is a large oval airduct on the Top right (when facing forward) just wanted to mention that... pluse the two air ducts... Best |
just another up date on the heater box.. Guess I'm doing this so the next guy
has some insight.. The heat box is I think fiberglass, with a tin sheet plate on the side facing the firewall.. It is held in place by bent over metal tabs... The heater core is not really "held" in place, but there are 4 plastic nubs protruding and are held by a type of (c clamp) remove this clamp and turn the nub quarter turn.. there is a slot for a striaght screw driver. then just pull up on the heater core.. Like always take care when bending those metal tabs when removing the metal plate.. it needs that even pressure all around the box... Best |
