Installing Vintage air
Just ordered Vintage Air for my 65 Falcon. I'm a little nervous about doing the install.Has any of you guys installed the VA with a switch to turn off the compressor when you go full throttle? When I jump on it I shift at 6400 to 6600 rpms. If I'm running the air at that rpm will it damage the compressor? Has anyone installed Vintage Air along with power steering with the GM Saginaw pump? VA told me they do not make a bracket to fit the GM pump.I installed Borgenson power steering and don't want to switch out my new chromed GM pump.I think I will have to make me a bracket for this set up.Any help would be greatly apprecitated. Roger
Got it installed
I finished in stalling the Vintage Air a while back. Man does it feel great cruising on the hot days. The air works great, I turn it on the lowest setting and it keeps the inside real cool. If I turn it up 1/2 way it will run you out. I just checked the heat out a couple days ago when it was in the high 30's and it work great. I am more than pleased with the results.Alot of work and cash , but worth every penny.
https://cimg8.ibsrv.net/gimg/www.for...908e673c39.jpg |
