Motor mounts
Hello
I'm looking at buying a 62 galaxie. just for info has anyone done an engine swap to a Ford SB.. and what motor mounts did you use thanks |
Regarding motor mounts
I guess no one else has come up with an answer either, but
after lots of research, since the 289 was available in the early ( 64 +) on the mid a big size Ford, you can use that motor mount for the Frame then you need to make a plate to mount it to the block... hope that helps others besides myself. Best |
