Play in 302 fuel pump 2 part eccentric
Have an engine noise that sounds like it is coming from the timing cover. Discovered that there is a huge amount of play in the 2 part fuel pump eccentric. Is this normal, it it rotates easily and moves a lot front to back.
Are we talking about a fuel pump push rod and eccentric that is operated off the cam mounted on the camshaft gear? If we are , the rod used to wear and sounded just like a connecting rod bearing, but could not be cancelled out shorting out any plugs. If the fuel pump arm was worn , it required replacing the fuel pump itself.
jozepy24
07-13-2019 05:21 AM
fordexpedition2006
04-21-2017 05:23 PM
