Transmission Swap on a '57 Fairlane
I have a '57 Fairlane that has a 1958 352FE in it with a 1958 Fordomatic transmission. I would like to swap the Fordomatic out and go with a floor shift manual transmission. What tranny could I use in this application?
Thanks. |
u might need a c6 i think 352fe is big block
Originally Posted by BIG BLOCK390
(Post 74870)
It is a big block. |
Originally Posted by 57Fairlane
(Post 74854)
1958 1964 FORD 352 390 406 427 3 & 4 SPEED MANUAL TRANSMISSION BELL HOUSING | eBay A doner car with manual transmission compatable to your yr. make, model car could be used to install the clutch pedal assembly. Aftermarket clutch pedal assemblies are also available. Here are a couple of links to give you an idea... Wilwood Brake/Clutch Pedal Assemblies - SummitRacing.com Wilwood Brake & Clutch Pedal Assemblies - JEGS |
Originally Posted by thexlo8ers
(Post 74887)
Ford used the BorgWarner T-10 manual transmission between about 1956 to 1965. They came available with floor shifters. To bolt the T-10 to your 352FE you may need...
1958 1964 FORD 352 390 406 427 3 & 4 SPEED MANUAL TRANSMISSION BELL HOUSING | eBay A doner car with manual transmission compatable to your yr. make, model car could be used to install the clutch pedal assembly. Aftermarket clutch pedal assemblies are also available. Here are a couple of links to give you an idea... Wilwood Brake/Clutch Pedal Assemblies - SummitRacing.com Wilwood Brake & Clutch Pedal Assemblies - JEGS Thanks for the help. |
