Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Get it started
Old 09-11-2017, 03:06 PM
tklepp's Avatar
Default Get it started
Ok - new here so HELLO.
Just picked up an 88 B2 for $250. It was ran out of gas and the t/c was stuck in N.
I checked the gas reserve on the frame and it had gas. I checked the fuel pump on the frame and it had gas. I checked the fuel regulator at first it was damp but then after playing with it, it is now dry.
I have checked the initia switch on the passenger side. It is white and doesnt seem to be engaged or tripped.
I found the relay on the passanger side under hood. I dont know how to test it.
Can someone explain in the simplest of terms how to test the fuel pumps by jumping the relay. ( I hope I am stating that correctly )
jerbud01
11-29-2006 05:29 PM
robcat
04-16-2006 01:40 AM
KCSPORTS
01-09-2006 03:14 PM
KCSPORTS
09-21-2005 01:23 AM
pamolnar76
09-15-2005 06:52 PM
Quick Reply: Get it started
