Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
1987 bronco 4.9l straight 6 issue
Old 04-25-2018, 10:22 AM
Acadian1's Avatar
Default 1987 bronco 4.9l straight 6 issue
Hey guys I just got a 1987 Ford bronco with the 4.9l in-line 6. It has been sitting for about 2 years. Sometimes it is hard to start without starting fluid but when it starts it will start up every time until it sits overnight. It idles good but if you give it a lot of gas it’s like it smothers out and almost dies until you let off. If you ease into the throttle it will rev up as high as you let it and it will hold at that rpm. The fuel pumps had good pressure. Has a new fuel pressure regulator and a new fuel pump relay. It was missing a vacuum hose from the vacuum tee to the map sensor. If you put that hose on it will start sputtering and almost dies. I know it’s a lot but any help would be greatly appreciated
Old 04-25-2018, 07:53 PM
Map sensor wire colors shoud be;
Blk-Wht = Grd
Drk Blu-Lt Grn= Signal to ECA
Org-Wht= 5 Volt Ref
With Key on engine off KOEO
Signal wire to ECA should read 1.55 - 1.63 Volts Anything else, replace MAP
87broncofrankinstien
02-10-2010 03:41 PM
benz_020
02-26-2006 09:11 PM
benz_020
02-26-2006 09:06 PM
CobieCane
09-07-2005 02:08 AM
semperfi48103
08-30-2004 02:28 AM
Quick Reply: 1987 bronco 4.9l straight 6 issue
