Engine Swap
I have searched around and think it may be easier to just ask. I have a 1994 Ford Bronco with 302. I also own a 93 Ford E-van with 351w that will be my donor. Engine swap is not an issue but I would like to know what changes I need to make on the 351 before I attempt to drop it in. I think the oil pan needs changed(but uncertain) Maybe the mounts? Both are efi system so the harness should be same? Does the ecu need to be changed also?
