Ford Bronco One of the original SUVs, offered in both a full size Bronco, or the more compact Bronco II.
Get it started
Old Sep 11, 2017 | 03:06 PM
tklepp's Avatar
Default Get it started
Ok - new here so HELLO.
Just picked up an 88 B2 for $250. It was ran out of gas and the t/c was stuck in N.
I checked the gas reserve on the frame and it had gas. I checked the fuel pump on the frame and it had gas. I checked the fuel regulator at first it was damp but then after playing with it, it is now dry.
I have checked the initia switch on the passenger side. It is white and doesnt seem to be engaged or tripped.
I found the relay on the passanger side under hood. I dont know how to test it.
Can someone explain in the simplest of terms how to test the fuel pumps by jumping the relay. ( I hope I am stating that correctly )
jerbud01
Nov 29, 2006 05:29 PM
robcat
Apr 16, 2006 01:40 AM
KCSPORTS
Jan 9, 2006 03:14 PM
KCSPORTS
Sep 21, 2005 01:23 AM
pamolnar76
Sep 15, 2005 06:52 PM
