Help 84 Bronco II XLT
I have a problem locating the right water outlet valve (which has cracked). All parts found do not fit and are different then the original. I have tried junk yards and online searches with no help. I did find one at a junk yard but it also cracked. Do I need to change out something entirely or is this just an elusive part?
Also are all 1980s Rangers and Bronco II spark plugs gapped the same? |
Welcome to the site..
Can you post a image or two ? |
4 Attachment(s)
https://www.fordforum.com/forum/atta...1&d=1461208475
https://www.fordforum.com/forum/atta...1&d=1461208475 don't know if I attached the images correctly...please let me know this is old software. |
replied with photos love your HD ford
1 Attachment(s)
Have tried LMC Truck? their images aren't representative or your water outlet, but I'd bet they've run into it before.
You could use a Mustang II outlet, and add in a fitting for the coolant bypass. The cast iron units are more workable should you need to resize/tap the ports. Hoses may need to be sourced if the angle/length changes.. |
1 Attachment(s)
Mustang II waster outlet..
