how do i remove the front rotor from my 84 bronco
cant get the rotor off please help, thanks
RE: how do i remove the front rotor from my 84 bronco
first off i need to know if it is 4wheel drive..if so you have to pull the hub apart and get to the nut that holds the hub assembly and rotor to the spindle..you may need a special tool to remove the nut but it may be done with a screwdriver and a little patients.
