-   Ford Bronco (https://www.fordforum.com/forum/ford-bronco-31/)
-   -   overdrive problems (https://www.fordforum.com/forum/ford-bronco-31/overdrive-problems-41097/)
Walter T. Dec 17, 2019 03:46 PM
overdrive problems
Overdrive flashes off, reverse has no power, does not throw a code. Suggestions?
hanky Dec 18, 2019 02:31 AM
The blinking of the OD light is telling us something is going on with the trans.
Usually it will set a code for anytime that light decides to start blinking.
If little or no reverse, check all conditions that activate reverse.
Walter T. Dec 19, 2019 07:21 AM
Hey Hanky, Thanks for the reply. The trouble is it is not throwing a code. I have replaced the switch on the gear shift and still nothing. Without a code, I do not know where to start.
hanky Dec 19, 2019 12:28 PM
The controlling parts don't seem to be getting the message,, so I would start with checking the switch at the trans that indexes what gear position you are choosing..
Walter T. Dec 21, 2019 09:46 AM
Thanks Hanky. Merry Christmas!
