'00 SVT major start, hesitation, stall problem
Greetings, new 86k Contour SVT owner-
Besides the above, it finally threw P1132 and P1152 codes.
I see a new fuel pump / filter... any specific pointers to minimize diag?
Testing components?
Specific vac lines, etc?
When it runs, it's a hoss, would love to get in shape asap.
Thanks!
Testing components?
Thanks!
I would pull one or two plugs and see what they look like.
If the system is trying to overcome a lean condition by continuing to add fuel confirm , no severe vacuum leaks, ie intake gskts , hoses etc.
MAF sensor could be sending false info.
Check PCV system.
Check PCV system.
Someone is here!
I was wondering if the forum was still alive... thanks for the tips.
20 degrees in the garage, I'll let it run (I hope) for a bit with the French drain hoses stuffed onro the pipes, out under the door and mess around.
Being an optimist, I am looking forward to a hoot in this new toy!
Had Focus SVT's, now this one...
Testing components?
Thanks!
Testing components?
Thanks!
Yargh
Thanks hanky, good tip.
There's something else very amiss, so the diagnosis continues. it barely runs, won't rev. I'm thinking fuel, as I nursed it up on the wheel ramps, it sounded fine for a bit! Fuel gauge went from 1/4+ tank to E and fuel light lit.
The seller claimed he replaced the pump and filter, so that's my next project.
-Tom
-Tom
3 codes today
gAk! What's wit this thing?!?
Cleaned TB and ports, new gasket, new plugs, dielectric applied, cleaned MAF, checked vac hoses, reassembled carefully.
After all that:
Blowing rich, rough idle; secondary's open, revs, stumbles, then bogs ...
After running (then stalling) a few times:
TPS P0122
MAF P0102
VSS P0500
Note that fuel light is on, but not empty .
After all that:
TPS P0122
MAF P0102
VSS P0500
Testing components?
Thanks!
Testing components?
Thanks!
digital_diversion
06-20-2013 09:10 PM
Bob Wells
12-17-2006 11:24 PM
