Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Window Scraping noise
Old 03-25-2009, 03:25 PM
MasDub's Avatar
Default Window Scraping noise
My driver side window makes a scraping noise that sounds like metal scraping on glass, but there are no marks on the glass. I took the door panel off and I do not see anything that is getting in the way of the glass itself. Any idea what could be the problem?
Old 12-30-2010, 04:31 PM
bodmd98's Avatar
Replace the window regulator/cable/motor as an integral unit. Over time, the drivers window destroys the cable tracks and pulleys (plastic) and the cable begins to drag on metal parts, hence the grinding noise. Normally a two man job, but can be done by one person if you have an assortment of wooden blocks to support the glass which you will remove in order to replace the regulator assembly.
makuloco2000
08-24-2014 06:14 PM
bdewilde
11-09-2008 08:25 PM
riccony
01-09-2008 07:02 AM
degussa
06-07-2005 06:53 PM
cocobob
01-12-2005 03:51 PM
Quick Reply: Window Scraping noise
