1998 contour + 1995 SHO manual
Will the 3.0L heads and intake manifold bolt on to the 1998 SVT contour motor??
Any info would be great. Thanks Kyle |
The motors are not the compatable.
The Contour SVT heads are good heads but so to are the heads on the later Taurus 3.0 DOHC and Escape motors which will bolt on. The SHO motor is designed by Yamaha. |
If you want more info about Contours you should join: Contour.org.
