1998 ford contour...need help
About once a week I would get only cold air coming out of the heater and the temp gauge would go to overheat but then it kicks in and I get warm heat and the gauge goes back to normal so I thought it was the thermastat sticking so I put a new one in but it didn't solve the problem. Have any ideas what it might be
RE: 1998 ford contour...need help
What size engine? Could be water pump, heater core clogged, low on coolant?
the size of the engine is 2.5 litre
make sure you put the thermostat in correctly. have the EGR valve checked. check your water pump belt.
| All times are GMT -5. The time now is 06:33 AM. |
