Ford Contour While only built on a short time span, the Contour was very popular with people of all driving styles, from the base model making for a great family car, to the SVT making a great track toy.
Temperature Gauge
Old 11-04-2006, 12:41 AM
fordfan419's Avatar
Default Temperature Gauge
The temperature gauge on my 98 Contour is pegged. I have no signs of overheating, coolant levels are good, no telltale smell of overheating. A coworker told me that the problem is likely a bad wiring connection to the gauge or the gauge has failed but not a thermostat issue. Any suggestions?
Old 11-26-2006, 04:59 AM
Default RE: Temperature Gauge
Bad wiring is a good guess, but it could also be a bad relay or temp sensor. Guages usually are a last resort check.
Old 06-16-2007, 06:57 PM
There is a TSB about this. TSB 98-21 Oct 3 1998
Old 10-20-2007, 03:04 PM
what does TSB mean? and where can I get a copy. I have a similiar problem except my gauge doesn't move at all.
Please advice.
Old 10-25-2007, 05:03 PM
I looked under Ford TSB for a 1998 Contour and I can not find the below mentioned TSB. Is it located in a different file??
(There is a TSB about this. TSB 98-21 Oct 3 1998)
Old 05-17-2011, 04:12 PM
Tman24's Avatar
Default temp gauge
I have the same problem on my 98 there are 2 sencers on the thermostat housing 1 or both are bad. one is for the gauge the other is for the computer.
Old 05-08-2015, 01:28 PM
LADave's Avatar
There are two temperature sensors in the same general area. One runs the temp gauge, the other connects to the computer. Sounds like the gauge sensor is bad, or maybe a wiring issue. If you get one of those OBD-2 scanners that connects to a computer (e.g. laptop), you'll see what the computer sensor is saying about temps. Generally that one seems more accurate.
walnut777
09-13-2009 08:00 PM
nflz32
12-30-2008 03:19 PM
msting
10-02-2007 12:07 PM
mcf
12-20-2006 07:43 PM
Kronos
07-13-2005 07:04 PM
Quick Reply: Temperature Gauge
